[OpenLayers-Dev] Cant login to file a bug.
Eric Lemoine eric.lemoine at camptocamp.com
Wed Sep 22 01:10:26 EDT 2010
On Tuesday, September 21, 2010, Phil Scadden <p.scadden at gns.cri.nz> wrote:
>   If I try to login so I can file a bug, I get error:
> "No handler matched request to /osgeo_login.html"
Use <http://trac.osgeo.org/openlayers>.
> Bug by way is that if you change displayprojection with map.setOptions,
> then displayProjection property is changed, however the latlon supplied
> to formatOutput handler is still in the old projection.
It is expected. Try to change the MousePosition control's
displayProjection property instead.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
