[OpenLayers-Dev] There are two bugs in Control.Measure.
Xavier Mamano (jorix) xavier.mamano at gmail.com
Thu Sep 23 17:20:07 EDT 2010
Hi list,
The problems are:
1.- The last measure can be a "measurepartial" and less that the correct
measure.
2.- Measuring and immediately turns off the control, a "measurepartial" can
be triggered after the control is deactivated.
I opened the ticket http://trac.osgeo.org/openlayers/ticket/2820 with 2.10
RC2. Now that the release 2.10 is closed I will again mention the problem
thinking 2.11.
The ticket contains a test and a patch.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/There-are-two-bugs-in-Control-Measure-tp5564767p5564767.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
