[OpenLayers-Dev] Using coordinates from a MySQL-DB with OL
Thomas81 sthomas at partybombe.de
Wed Aug 10 06:15:52 EDT 2011
Dear all,
it might be an easy question. However, is it possible to use coordinates (4
pieces) stored in a MySQL-DB to draw bounding boxes in combination with
OpenLayers? Will it be fast enough, if we think about up to 500 polygons?
Could these bounding boxes be clickable and show additional information?
I saw an easy example of textlayer, which nearly shows the functionalities
but the data source is a textfile, not a MySQL-DB.
Should it be a vector layer with polygons? Or is a maker-boxes layer more
appropriate?
Kind regards,
Thomas
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-coordinates-from-a-MySQL-DB-with-OL-tp6671766p6671766.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
