[OpenLayers-Dev] Re: Using coordinates from a MySQL-DB with OL
midi info at digitale-wegeverwaltung.de
Wed Aug 10 08:47:06 EDT 2011
parsing json, xml, gml can take a lot of time and costs performance.
after testing a lot we send our data this way:
lat#lng#value1#value2
lat#lng#value3#value4
in javascript you only need a split ('#') putting data in arrays.
the split function is very fast. splitting needs  1-2ms, parsing x00 to x000
ms.
that is the fastest method.  no standard , but fast ;-)
an other advantage is less (50-80%) data (no tags, only a #)
500 poly with 15.000 - 25.000 Points are no problem.
a server side optimization is storing all values in an extra text field
(lat#lng#value1#value2)
so you dont need to concat the values. one "echo" is enough. no standard,
but fast ;-)
i figured the idea out after reading the articel below-mentioned
http://code.flickr.com/blog/2009/03/18/building-fast-client-side-searches/
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-coordinates-from-a-MySQL-DB-with-OL-tp6671766p6672225.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
