[OpenLayers-Dev] Wrong revision number when building
Bart van den Eijnden bartvde at osgis.nl
Thu Aug 25 14:31:18 EDT 2011
Alexandre,
it has the last revision number for the file SingleFile.js, which is 10995, so your build should be fine:
http://trac.osgeo.org/openlayers/browser/trunk/openlayers/lib/OpenLayers/SingleFile.js?rev=12278
Best regards,
Bart
OSGIS - http://osgis.nl
On Aug 25, 2011, at 7:23 PM, Alexandre Dube wrote:
> Hi,
>  I just made a build out of OpenLayers r12278 and the revision number it shows is r10995.  I looked in the single file to look for recent changes and it has them, so it's just a matter of wrong revision number.
>  Any hint ?
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110825/16fea1e3/attachment.html
More information about the Dev mailing list
