R: [OpenLayers-Dev] Problems with the display in IE
Xavier Mamano (jorix) xavier.mamano at gmail.com
Thu Dec 1 11:14:09 EST 2011
Hi Giuseppe,
Closure Compiler is a great tester of code, you must correct this error:
JSC_TRAILING_COMMA: Parse error. Internet Explorer has a non-standard
intepretation of trailing commas. Arrays will have the wrong length and
objects will not parse at all. at line 86 character 12
[ aziende, ],
_______^
I have used http://closure-compiler.appspot.com/home by adding the statement
"var OpenLayers={};" before its code.
Xavier Mamano
Giuseppe Lo Burgio wrote
> I've created another page, in this case the page load but the error
> persist:
> http://www.ibasblog.it/confimap/index_sample_2.html
> thanks
> Giuseppe
> -----Messaggio originale-----
> Da: openlayers-dev-bounces at .osgeo
> [mailto:openlayers-dev-bounces at .osgeo] Per conto di Phil Scadden
> Inviato: lunedì 28 novembre 2011 23:56
> A: openlayers-dev at .osgeo
> Oggetto: Re: [OpenLayers-Dev] Problems with the display in IE
> I tried to look at your site, but I got
> 404 - cant find
> http://www.ibasblog.it/confimap/js/jquery.bubblepopup.v2.1.5.min.js
> (and a blank space where map should be).
> Download openlayers source and link your page to the debug (/lib) version.
> That will give you better information.
> Notice: This email and any attachments are confidential. If received in
> error please destroy and immediately notify us. Do not copy or disclose
> the
> contents.
> Dev mailing list
> Dev at .osgeo
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Dev mailing list
> Dev at .osgeo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problems-with-the-display-in-IE-tp7040588p7051087.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
