[OpenLayers-Dev] mobile-jq example does not work with current jQuery Mobile (was: Current and Future jQuery mobile will not work with OpenLayers.)
Andreas Hocevar ahocevar at opengeo.org
Tue Jul 12 06:08:36 EDT 2011
On Tue, Jul 12, 2011 at 12:05 PM, Noli Sicad <nsicad at gmail.com> wrote:
> I got this same error (below)  in my 2 other jquery mobile projects
> aside from the mobile-jq example from OpenLayers.
This only means that the map container does not have a size, probably
because it is a sub-element of a jqmobile page. Adding a
style="width:100%;height:100%;"
attribute to the map div may help.
Andreas.
> OpenLayers.js:1234TypeError: Result of expression 'size' [null] is not
> an object.
> This is line 1234 (below)
> var schema={};this.readNode(data,schema);return
> schema;},CLASS_NAME:"OpenLayers.Format.WFSDescribeFeatureType"});OpenLayers.Renderer=OpenLayers.Class({container:null,root:null,extent:null,locked:false,size:null,resolution:null,map:null,initialize:function(containerID,options){this.container=OpenLayers.Util.getElement(containerID);OpenLayers.Util.extend(this,options);},destroy:function(){this.container=null;this.extent=null;this.size=null;this.resolution=null;this.map=null;},supported:function(){return
> false;},setExtent:function(extent,resolutionChanged){this.extent=extent.clone();if(resolutionChanged){this.resolution=null;}},setSize:function(size){this.size=size.clone();this.resolution=null;},getResolution:function(){this.resolution=this.resolution||this.map.getResolution();return
> this.resolution;},drawFeature:function(feature,style){if(style==null){style=feature.style;}
> Noli
> On 7/12/11, Andreas Hocevar <ahocevar at opengeo.org> wrote:
>> It also doesn't mean that jQuery is broken. It only means that the
>> example does not work with later versions of jQuery than the one used
>> in the example.
>> Andreas.
>> On Tue, Jul 12, 2011 at 11:35 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>> Hi Andreas,
>>> It is not OpenLayers that is broken for sure.
>>> It is jQuery mobile that is broken.
>>> I like to see another OpenLayers and jQuery mobile project that is
>>> working.
>>> Noli
>>>> Hi Noli,
>>>> the subject of this thread adds a lot of drama to to the content that
>>>> is not actually there. So I changed the subject. Anybody is welcome to
>>>> fix the mobile-jq example. A non-working example does not mean that
>>>> OpenLayers is broken.
>>>> Regards,
>>>> Andreas.
>>>> On Tue, Jul 12, 2011 at 10:43 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>>>> Hi Andreas,
>>>>> I just tested the official jQuery Mobile example in OL 2.11 RC1.
>>>>> It is not working with the beta1 jQM release.
>>>>> You can download.
>>>>> 1.I am using mobile-jq.html in OpenLayers-2.11-rc1.tar.gz
>>>>> http://www.openlayers.org/download/
>>>>> 2. jQuery Mobile --- Zip File: jquery-mobile-1.0b1.zip (JavaScript,
>>>>> CSS, and images)
>>>>> http://jquerymobile.com/download/
>>>>> 3. jQuery 1.6.2
>>>>> http://docs.jquery.com/Downloading_jQuery
>>>>> The jquery mobile 1.0b1pre is working after this version. It is not
>>>>> working.
>>>>> Noli
>>>>>> Can we have a link to an example that shows the issue, which uses
>>>>>> unminified versions of both OpenLayers and jQuery? This will make it
>>>>>> easier to locate the issue.
>>>>>> Thanks,
>>>>>> Andreas.
>>>>>> On Mon, Jul 11, 2011 at 5:43 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>>>>>> Hi,
>>>>>>> I like to inform everybody that the current and future releases of
>>>>>>> jQuery Mobile will not work with OL until this issue is resolved.
>>>>>>> https://github.com/jquery/jquery-mobile/issues/search?q=OpenLayers
>>>>>>> If you know what is causing the problem, please let us.
>>>>>>> Noli
>>>>>>> _______________________________________________
>>>>>>> Dev mailing list
>>>>>>> Dev at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>>>>>> Andreas Hocevar
>>>>>> OpenGeo - http://opengeo.org/
>>>>>> Expert service straight from the developers.
>>>>> Dev mailing list
>>>> Andreas Hocevar
>>> Dev mailing list
>> Andreas Hocevar
> Dev mailing list
Andreas Hocevar
More information about the Dev mailing list
