[OpenLayers-Dev] Re: mobile-jq example does not work with current jQuery Mobile (was: Current and Future jQuery mobile will not work with OpenLayers.)
Eric Lemoine eric.lemoine at camptocamp.com
Wed Jul 13 01:39:24 EDT 2011
On Tue, Jul 12, 2011 at 5:43 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> Hi,
> the mobile-jq example on trunk is now updated to also work with newer
> versions of JQuery Mobile. Note that the example still uses the same
> version it used to, beause the fixContentHeight workaround does not
> work properly in later versions.
> Anyway, starting from the current mobile-jq example, people can update
> their applications. And maybe somebody can investigate how to properly
> size the content now.
Thanks a lot for updating the example Andreas!
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
