[OpenLayers-Dev] OL trunk + MapServer 6.0 + BBOX Strategy -> WFS server error. Invalid or Unsupported FILTER in GetFeature
Roald de Wit list at rdewit.net
Sat Jul 16 08:38:16 EDT 2011
Hey Andreas,
It's true that I don't set the FeatureNS. However, I *do* set the
featureType *and* the featurePrefix in my protocol options, which used
to be sufficient.
If you take the wfs-protocol.html example from trunk and replace
featureNS with: featurePrefix: 'topp', you'll see that the PropertyName
disappears from the WFS request (in the BBOX filter).
Is this expected behaviour, ie: can I not use featurePrefix anymore or
is it a bug?
Thanks, Roald
On 16/07/11 19:59, Andreas Hocevar wrote:
> Hey Roald,
> the PropertyName will still always be set, unless you have a poorly
> configured WFS protocol (i.e. no FeatureNS set).
> How is your protocol configured (the one that used to work in 2.10,
> but does not any more)? Maybe we find a better way to determine poorly
> configured protocols.
> FYI, the offending change came with
> http://trac.osgeo.org/openlayers/ticket/3368
> Andreas.
>> On Jul 16, 2011 8:25 AM, "Roald de Wit" <list at rdewit.net
>> <mailto:list at rdewit.net>> wrote:
>> Hi,
>> When trying out one of my apps with OL trunk, I get the following
>> error: "WFS server error. Invalid or Unsupported FILTER in
>> GetFeature". Whilst digging through the code, I noticed that the WFS
>> requests have changed: the PropertyName tag has been removed from the
>> BBOX Filter.
>> It seems possible to work around the problem by providing a
>> 'property' attribute to the BBOX filter, but since I use a WFS
>> protocol with a BBOX Strategy, this strategy does not allow me to add
>> this attribute to the filter without overriding the createFilter method.
>> It looks like this change is not in OL 2.11-RC1 but if RC2 will be a
>> re-branch from trunk (as crschmidt suggests in another thread), then
>> this could cause problems for people using MS 6.0.x with OL 2.11.
>> Alexandre Dube reported the same error on the MS trac a few days ago:
>> http://trac.osgeo.org/mapserver/ticket/3955. He might have run into
>> the same problem. Strictly speaking, it seems to be a MS bug and not
>> an OL one. But what if it takes a long time before this bug gets
>> fixed? And, could this be classed as a regression, since 2.10 does
>> not have this problem?
>> Regards, Roald
>> Dev mailing list
>> Dev at lists.osgeo.org <mailto:Dev at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
