[OpenLayers-Dev] OpenLayers Documentation link to example and some code snippets at the bottom - Suggestion
Noli Sicad nsicad at gmail.com
Mon Jun 13 20:00:01 EDT 2011
I would like to make a suggestion to dev team, that probably the
Openlayers documentation would be probably have some code snippets
(i.e. examples snippets of the OL project ) and a actual link to the
specific example.
R package has the feature and it is easier to understand those
functions, etc, if you can see the some code snippet on OpenLayers
project.
For example, KML,
Document
http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Format/KML-js.html#OpenLayers.Format.KML.OpenLayers.Format.KML
KML example
http://openlayers.org/dev/examples/kml-layer.html
Some people would read the source code first,  then read the
documentation when it is hard to follow :-).
Not to mention good for new comers.
Thanks.
Regards, Noli
More information about the Dev mailing list
