[OpenLayers-Dev] Re: Features move around when map panned
Peter Körner osm-lists at mazdermind.de
Thu Jun 16 18:25:47 EDT 2011
Hi
can you supply a bare-metal demo with only the parts needed to
demonstrate the problem (ie a html page with a single div of fixed size
and a map in it with only the layers and controls needed to causethe
issue).
Can you also tell about which Browser you are using?
Peter
Am Donnerstag, den 16.06.2011, 13:38 -0700 schrieb amajedi:
> when I activate the selectFeature control manually via a button after some
> features have loaded, then pan around the map, everything works
> fine...However when I activate the control right after creating the select
> control without any features on the map yet, the features start moving
> around again
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Features-move-around-when-map-panned-tp6358063p6484678.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
