[OpenLayers-Dev] OL Mobile Development
Matt Priour mpriour at kestrelcomputer.com
Fri Jun 24 00:36:02 EDT 2011
Aaditya,
The mobile code is in the SVN trunk and the 2.11RC release. You will not find it in the 2.10 release.
To have an uncompressed version of OpenLayers.mobile.js, you will need to build it yourself. This is nearly trivial as the build directory has the mobile config.
To build an uncompressed version you would just execute
./buildUncompressed.py mobile
in the build directory. Then rename the OpenLayers.js that is produced to OpenLayers.mobile.js and move it to where you want to use it.
Matt Priour
Kestrel Computer Consulting
>Date: Thu, 23 Jun 2011 10:19:45 -0700
>From: Aaditya Shidham <aashidham at gmail.com>
>Subject: [OpenLayers-Dev] OL Mobile Development
>To: openlayers-dev at lists.osgeo.org
>Message-ID: <45B974D5-B328-4A47-BF43-CA38F9740D5E at gmail.com>
>Content-Type: text/plain; charset="us-ascii"
>Hello Fellow Developers,
>I am new to the OL community, so sorry if this is an obvious question. I am trying to use OL for mobile development but am having trouble finding mobile code in the tar.gz or the SVN source tree on http://openlayers.org.
>Where can I access the source code that was used to demonstrate http://openlayers.org/dev/examples/mobile.html? I can't find mobile.js, style.mobile.js. or OpenLayers.mobile.js used here in any documented source code >tree. And I can't find OpenLayers.mobile.js in an uncompressed format at all.
>Thanks,
>Aaditya
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110623/d25818c9/attachment.html
More information about the Dev mailing list
