[OpenLayers-Dev] Re: OSM layer panning at trunk
Denis Rykov rykovd at gmail.com
Thu Mar 3 02:35:15 EST 2011
Thanks for reply. I've changed buffer property and now all works flawlessly!
On Thu, Mar 3, 2011 at 1:33 PM, Bruno Binet <bruno.binet at camptocamp.com> wrote:
> Or because of this:
> http://trac.osgeo.org/openlayers/ticket/2998
> On 3 March 2011 08:11, Bart van den Eijnden (OSGIS) <bartvde at osgis.nl> wrote:
>> The default value of buffer was changed from 2 to 0, which probably
>> explains this?
>> Best regards,
>> Bart
>>> http://gis-lab.info/share/DR/sandbox/osm-release.html
>>> http://gis-lab.info/share/DR/sandbox/osm-trunk.html
>>> On Thu, Mar 3, 2011 at 1:01 PM, Denis Rykov <rykovd at gmail.com> wrote:
>>>> Hi devs!
>>>> I've made two examples with different version of OpenLayers - 2.10 and
>>>> trunk version.
>>>> Both examples contains map with one OSM layer and shows different
>>>> behavior while map panning.
>>>> I guess that at the second (trunk) example while panning tiles loads
>>>> only after moveend event, but in the first example it does not.
>>>> Could anyone explain this behavior?
>>> Dev mailing list
>>> Dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>> Dev mailing list
> Bruno Binet
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Mail : bruno.binet at camptocamp.com
> http://www.camptocamp.com
More information about the Dev mailing list
