[OpenLayers-Dev] testing OL for being prepared at the ready event
Bart van den Eijnden bartvde at osgis.nl
Wed Mar 16 07:19:55 EDT 2011
For GeoExt we have a similar issue with Ext.onReady, we advise people who want to initialize vector layers to use body onLoad instead. It's because the VML Renderer needs document.namespaces.
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
On Mar 16, 2011, at 12:17 PM, Martin Saturka wrote:
> Hi,
> we use OpenLayers at environments where we need to use JQuery based
> "ready" event for the maps initialization, i.e.
> $(document).ready(function() { do_map_init(); }
> It fails for some situations, mostly and usually for MSIE. I have
> found (for the current stable 2.10 version of OL) that it could be
> checked via
> OpenLayers.Util.test_ready = function() {
>    var aux_layer = null;
>    try {
>        aux_layer = new OpenLayers.Layer.Vector("auxiliary");
>    } catch (e) {
>        return false;
>    return true;
> I have a timer for checking it, until it is ok. Is there any plan for
> having a regular checker? Am afraid that the thing above could be
> wrong for next releases of OL.
> M.
> Martin Saturka
> Software Engineer, Sourcefabric
> www.sourcefabric.org
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
