[OpenLayers-Dev] Hover & Popup Example
Andreas Hocevar ahocevar at opengeo.org
Thu Mar 24 06:00:57 EDT 2011
You could turn your findings into an example, attach it as patch to a ticket that you create, and then we can add it to the examples collection. See http://trac.osgeo.org/openlayers/wiki/HowToContribute.
That's how OpenSource works.
Regards,
Andreas.
On Mar 9, 2011, at 11:21 , shitake83 wrote:
> Hi Folks, ive been struggling to get this to work for some time, until
> yesterday i finally got it to work.
> I had to implement this for my workplace and the examples i found couldnt
> help me. I looked around the net and found out that alot of people are also
> struggling with this problem.
> Finally i got it to work and eventhough the functionality is not something
> really special, im still sure that if this would/could be introduced into
> the openlayers examples, many people could take advantage of this.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Hover-Popup-Example-tp6153123p6153123.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
