[OpenLayers-Dev] Re: HTML template popup manager
Xavier Mamano (jorix) xavier.mamano at gmail.com
Tue Nov 1 09:21:00 EDT 2011
With two examples I think it's enough: "olsocial" and multi layer.
I think "smart-popup.html" is not necessary.
Example multi layer using URI instead of Id:
 * See: http://jorix.github.com/SmartPopup/smart-popup2.html
 * See templates in:
https://github.com/jorix/SmartPopup/tree/gh-pages/templates
@Javier Carrasco: Are there any ticket for proposing "olsocial"?
Xavier
Noli Sicad wrote:
> 1+ to SmartPopup name.
> Then include the 3 examples or more.
> 1. http://gis.prodevelop.es/olsocial/
> 2. http://jorix.github.com/SmartPopup/smart-popup.html
> 3. another one with 3 GeoJSON layers with LayerSwitcher - remove and add
> I think it would be good to include more GeoJSON layers aside from
> Sprinter GeoJSON, 3 layers with LayerSwitcher.
> Noli
> On 11/1/11, Xavier Mamano (jorix) <xavier.mamano@> wrote:
>> Hi Javi,
>> To me it seemed an interesting proposal. I think the thing can be:
>>  * example (draft): http://jorix.github.com/SmartPopup/smart-popup.html
>>  * code of the control: http://jorix.github.com/SmartPopup/SmartPopup.js
>> I think this would be a sufficiently OpenLayers coding, but I'm not
>> OpenLayers team member.
>> I added an automatic behavior, if the layer has the property "templateId"
>> is
>> not necessary to add it.
>> TODO:
>>  * Also allows searching the templates by ajax?.
>>  * Write tests.
>>  * Write the method removeLayer.
>>  * Documenting.
>>  * Name?: I like the name SmartPopup
>>  * Constructor options.
>> Xavier
>> Javier Carrasco wrote:
>>> Hello,
>>> I wrote a small piece of code to easily add popups to vector layers
>>> using html templates.
>>> Example: http://gis.prodevelop.es/olsocial/
>>> <http://gis.prodevelop.es/olsocial/>
>>> SmartPopup is a manager that helps  users to add popups to vector layers
>>> without dealing with controls or events and without concatenating
>>> strings. The name (SmartPopup) is wrong, TemplatePopupManager would be
>>> better.
>>> I think it could be useful for other users but maybe it is not very
>>> OpenLayers-style. Maybe it should be a control instead of a separate
>>> object, width and height of the popup and the popup style (like
>>> FramedCloud) should be configurable, etc.
>>> Could you developers give me some advices to make my code more
>>> OpenLayers-style?
>>> Thank you
>>> Javi
>>> Dev mailing list
>>> Dev at .osgeo
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/HTML-template-popup-manager-tp6948565p6949634.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
>> Dev at .osgeo
> Dev mailing list
> Dev at .osgeo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/HTML-template-popup-manager-tp6948565p6951642.html
More information about the Dev mailing list
