[OpenLayers-Dev] svn mirror
Andreas Hocevar ahocevar at opengeo.org
Thu Nov 3 13:06:42 EDT 2011
I just tried to bring the svn repository up to date with the git one, but this ended up as one big commit. Do we care? If so, I apologize. git dcommit --dry-run did not output anything suspicious, so I went for the real thing.
Here is what I did:
git clone git at github.com:openlayers/openlayers.git openlayers-git-svn
cd openlayers-git-svn
git svn init --trunk=trunk/openlayers http://svn.openlayers.org
git checkout 8bcbb069b56c3a810a94c55224e726a13d3096a2
git rebase --onto remotes/trunk --root master
git fetch origin master
git merge -Xtheirs FETCH_HEAD
git svn dcommit --add-author-from --use-log-author --username openlayersgit
The "git checkout 8bcbb069b56c3a810a94c55224e726a13d3096a2" was supposed to set git to the last commit in svn (r12414).
The dcommit created a merge commit which I pushed to https://github.com/ahocevar/openlayers/commit/ad44399a2210adf34e2e378a42b382ee2f0b8a34 for posterity. The last revision on master that *should* have ended up in svn was 0bf1169c1695571660ccc6a1c41b781769d641eb
Please let me know if you're unhappy with what I have done, and I'll try to fix it. Otherwise I'll just leave it as is, and I volunteer to change the cron job that updates the examples and docs on the OpenLayers website to build directly from git instead of the svn mirror.
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
