[OpenLayers-Dev] Advice on best way to extend a OL class.
Eric Lemoine eric.lemoine at camptocamp.com
Sun Nov 13 17:06:26 EST 2011
On Sunday, November 13, 2011, Phil Scadden <p.scadden at gns.cri.nz> wrote:
>>   The "Strategy Cluster Extended" would be a good class extending
>> example :
>> http://openlayers.org/dev/examples/strategy-cluster-extended.html
> Thanks for that. Still got a javascript issue though.
> Suppose I extend linearRing with the swapXY method - call it linearRingEx.
> The code calling context though is:
>                             } else if (filter.type ===
> OpenLayers.Filter.Spatial.INTERSECTS) {
>                                 var geom = filter.value;
>                                 transformGeometry(geom);
>                                 geom.components[0].swapXY();
>                                 params.cql_filter = 'INTERSECTS(SHAPE,'
> + geom.toString() + ')';
> To call the swapXY method, I need to somehow cast the geom object (a
> superclass) so that the linearRing descendent is of linearRingEx. I am
> struggling to see how to do this in JS.
Why can't you just have a swapXY function that takes a LinearRing as its
1st argument and modifies it in place? Sorry if I'm not understanding your
issue.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20111113/a89975aa/attachment.html
More information about the Dev mailing list
