[OpenLayers-Dev] proposal: map.addLayer(object) as well as instance
Jachym Cepicky jachym.cepicky at gmail.com
Wed Oct 5 14:22:48 EDT 2011
it probably would be nice to have ExtJS-like possibility to initialize
objects (I would start with layers).
Now, you *have* to create instance of OpenLayers.Layer and than the
object can be added to map
map.addLayer(new OpenLayers.Layer.WMS(name,url, params, options));
What do you think about a option, that you would have to submit
object-like definition only:
map addLayer({
	CLASS_NAME: "OpenLayers.Layer.WMS",
	params: {
			layers: "0",
			version: "1.3.0"
	options: {
			isBaseLayer: false
It should not be too complicated to put such method in OpenLayers.Map
object.
What do you think, shall I write some proposal-patch, or do all agree,
that it is not needed at all?
Jachym
More information about the Dev mailing list
