[OpenLayers-Dev] How to find correct bounds to display an SVG at a correct location using addin inlineXhtml
Tanguy TM. Mezzano Tanguy.Mezzano at macq.eu
Thu Oct 6 06:23:54 EDT 2011
In order to display SVGs and make them interactive on a map, I found that useful addin called inlineXhtml.
The only problem I'm facing is that I could not find the correct bounds to display correctly my SVG at a precise location.
Thanks for your input,
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20111006/f0d0cb5a/attachment.html
More information about the Dev mailing list
