[OpenLayers-Dev] Re: How to find correct bounds to display an SVG at a correct location using addin inlineXhtml
Tanguy TM. Mezzano Tanguy.Mezzano at macq.eu
Mon Oct 10 05:18:29 EDT 2011
 Hello Harris,
Unfortunately, it doesn't come from spatial data/query but from a svg editor. For the moment, I don't want it to be scalable. I thus leave the width and height (120x120) in the svg tag, I set the  OpenLayers.Size(120,120) but I have no correct idea on which bounds to set in the OpenLayers.Bounds() if I want to pin the svg at some precise coordinates. I guess its linked to the resolution specified and the conversion of map units / image units.
Tanguy MEZZANO
-----Original Message-----
From: openlayers-dev-bounces at lists.osgeo.org [mailto:openlayers-dev-bounces at lists.osgeo.org] On Behalf Of hhudson
Sent: samedi 8 octobre 2011 08:25
To: dev at openlayers.org
Subject: [OpenLayers-Dev] Re: How to find correct bounds to display an SVG at a correct location using addin inlineXhtml
If you are adding a scalable SVG image, you will need to specify the image extent.  Depends how you created your SVG images in the first place - if the SVG's are generated from spatial data/query you should know the extent when you created the image.
Regards,
Harris.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-find-correct-bounds-to-display-an-SVG-at-a-correct-location-using-addin-inlineXhtml-tp6865466p6871934.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
Dev mailing list
Dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
