[OpenLayers-Dev] Re: OpenLayers 2.11 RC3
Tim Schaub tschaub at opengeo.org
Fri Sep 2 12:03:40 EDT 2011
At this point, I'm most interested in seeing 2.11 released before
FOSS4G.  I think for that to happen, we need to call it good now.
Regarding the fixed tickets listed as 2.12, I started changing those to
2.11, but it got very tedious.  If anybody else wants to take some time,
that would be helpful (there's also
http://trac-hacks.org/wiki/BatchModifyPlugin - I can vouch that it
works, but there is liability in bringing on abandoned plugins).
Tim
On 9/1/11 6:16 PM, christopher.schmidt at nokia.com wrote:
> On Sep 1, 2011, at 1:13 PM, ext Xavier Mamano (jorix) wrote:
>> Hi,
>> I think there are some mismatches between "root/branches/openlayers/2.11"
>> and the Tickets:
>> Tickets 2.11 with resolution fixed and *not applied* the branch 2.11
>> http://trac.osgeo.org/openlayers/ticket/3456 is fixed, but not on branch
>> 2.11.
> This was not marked pullup, so it was not pulled into 2.11.
> Tim, can you comment on whether you think this belongs in 2.11?
>> (I think it's the only one in this situation,
>> see "Modified" in
>> http://trac.osgeo.org/openlayers/query?status=closed&order=changetime&col=id&col=summary&col=changetime&milestone=2.11+Release&desc=1&resolution=fixed)
>> Tickets 2.12 with resolution fixed and *applied* the branch 2.11
>> Tickets applied in the trunk before 08.08.2011 are also in 2.11 branch
>> (excluding #3431, and #3352 fixed also by [12185]. See
>> http://trac.osgeo.org/openlayers/log/branches/openlayers/2.11)
>> The affected tickets are: #2247, #3440, #3433, #3438,, #3436, #3423, #3411,
>> #3407 , #3412, #3400, #3387, #3393, #3368, #3375, #3349, #3367, #3366,
>> #3365, #3354
>> (see "Modified" in
>> http://trac.osgeo.org/openlayers/query?status=closed&order=changetime&col=id&col=summary&col=changetime&milestone=2.12+Release&desc=1&resolution=fixed)
> Yes, anything that was in before RC2 got into 2.11 because we re-branched.
> Anyone who wants to can move those tickets to 2.11 and update the release
> notes; none of them are so crucial I intend to spend a lot of time
> harping on them :)
> -- Chris
>> Xavier Mamano
>> christopher.schmidt wrote:
>>> The OpenLayers Development Team is proud to announce the third release
>>> candidate of OpenLayers 2.11!
>>> As of 2.11-RC3, the OpenLayers 2.11 release closes an additional 8
>>> tickets,
>>> resolving a small number of issues with the previous release candidate.
>>> We invite you to help us test the 2.11 release candidate! To test 2.11
>>> in your applications, include the following tag in your
>>> OpenLayers-powered page:
>>> As always, the source is available at http://openlayers.org/download/.
>>> Bug reports can be filed in Trac, under the 2.11 RC3 version and 2.11
>>> milestone.
>>> Christopher Schmidt
>>> Dev mailing list
>>> Dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>> View this message in context: http://osgeo-org.1803224.n2.nabble.com/OpenLayers-2-11-RC3-tp6722816p6750818.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
Tim Schaub
OpenGeo - http://opengeo.org
Enterprise support for open source geospatial.
More information about the Dev mailing list
