[OpenLayers-Dev] addOptions and redraw
Bart van den Eijnden bartvde at opengeo.org
Thu Apr 12 04:04:57 EDT 2012
Ofcourse this is not a solution either, since the layer will not automatically turn on again, and it will be unchecked in a layer manager.
Best regards,
Bart
OpenGeo - http://opengeo.org
Expert service straight from the developers.
On Apr 12, 2012, at 9:31 AM, Bart van den Eijnden wrote:
> Hi Eric,
> the displacement issue was caused by calling display on the layer.
> If I use setVisibility all is fine.
> layer.setVisibility(layer.calculateInRange());
> I'll open up a ticket for the alwaysInRange issue.
> Best regards,
> Bart
> On Apr 11, 2012, at 7:43 PM, Bart van den Eijnden wrote:
>> Just tested, using map.setCenter() does not work.
>> I guess it's because the code block is protected by zoomChanged and centerChanged, and none of them changed in this case.
>> https://github.com/openlayers/openlayers/blob/master/lib/OpenLayers/Map.js#L1934
>> Would it not make sense to move this logic (visibility based on range) from the Map into the Layer? Ofcourse I am unaware of the history of all this.
>> I'll work on creating a minimal example to illustrate the issues first thing tomorrow morning.
>> Best regards,
>> Bart
>> On Apr 11, 2012, at 6:37 PM, Eric Lemoine wrote:
>>> On Wed, Apr 11, 2012 at 4:26 PM, Eric Lemoine
>>> <eric.lemoine at camptocamp.com> wrote:
>>>> On Wed, Apr 11, 2012 at 3:48 PM, Bart van den Eijnden
>>>> <bartvde at opengeo.org> wrote:
>>>>> Hey Eric,
>>>>> right, what I am doing now is calling display in the following way:
>>>>> layer.display(layer.calculateInRange());
>>>>> but it feels a bit weird to do it this way.
>>>> Yes, that's ugly. We really provide a better way to handle your case.
>>> Another thing you could try is call map.setCenter() (with no
>>> argument), this should turn off your out-of-range overlays.
>>> Regarding the displacement issue I'm interested to exactly know how to
>>> reproduce it.
>>> Eric Lemoine
>>> Camptocamp France SAS
>>> Savoie Technolac, BP 352
>>> 73377 Le Bourget du Lac, Cedex
>>> Tel : 00 33 4 79 44 44 96
>>> Mail : eric.lemoine at camptocamp.com
>>> http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120412/cff0838f/attachment.html
More information about the Dev mailing list
