[OpenLayers-Dev] Help with where to look for a bug - drawFeatures controls not working at ONE zoom level.
Phil Scadden p.scadden at gns.cri.nz
Thu Apr 26 17:17:24 EDT 2012
 >My guess is that you have a geometry that spans an area which exceeds
the SVG coordinate range and >cannot be split. Can you try if the Canvas
renderer gives you better results?
How do you specify that renderer? I know you can add renderers property
to a layer but the layer used by the polygon handler is created in the
OL code. Can you add a renderer property to the handler options when
creating the handler for drawfeature?
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
More information about the Dev mailing list
