[OpenLayers-Dev] Rework of Google layer leads to map div transparency
Denis Rykov rykovd at gmail.com
Fri Dec 7 16:36:21 PST 2012
Andreas, .olForeignContainer works for me!
Thanks.
On Sat, Dec 8, 2012 at 6:57 AM, Andreas Hocevar <ahocevar at opengeo.org>wrote:
> Hey Denis,
> try to set the <!DOCTYPE html> doctype in your document, instead of
> using a HTML4 doctype. If that doesn't work, you have to set the
> following css:
> .olForeignContainer { opacity: 1 !important; }
> Let us know which one works for you.
> Thanks,
> Andreas.
> On Fri, Dec 7, 2012 at 4:34 PM, Denis Rykov <rykovd at gmail.com> wrote:
> > Hi, Bart!
> > Sorry I can't provide minimal example, but my code is very simple.
> > Please take a look: http://tinyurl.com/cgblaad
> > On Fri, Dec 7, 2012 at 4:08 PM, Bart van den Eijnden <
> bartvde at opengeo.org>
> > wrote:
> >> Can you show us a minimal example to reproduce?
> >> Best regards,
> >> Bart
> >> OpenGeo - http://opengeo.org
> >> Expert service straight from the developers.
> >> On Dec 7, 2012, at 3:35 AM, Denis Rykov <rykovd at gmail.com> wrote:
> >> After recent rework of Google layer - in my application transparency of
> >> all elements of map div (including wms layers, pan-zoom buttons) becomes
> >> about 50%. Switching back from dev/OpenLayers.js to api/OpenLAyers.js
> solves
> >> the problem. _______________________________________________
> >> Dev mailing list
> >> Dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> > Dev mailing list
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20121208/bcb04833/attachment.html>
More information about the Dev mailing list
