[OpenLayers-Dev] Re: [OpenLayers] #3618: Problems with closure compiler under windows.
Xavier Mamano (jorix) xavier.mamano at gmail.com
Tue Feb 14 16:53:33 EST 2012
Hi Phil,
If you came from svn trac, the repository checkins from github are different
and have another number. Maybe this was the problem, I think from this point
is not prebisible you have problems, but in my case I left SVN.
Consider the option of using GIT (and GitHub, it has a useful help about
GIT), the first steps are hard but then... you can get a new horizon of
possibilities ;-)
Xavier
Phil Scadden wrote
> Okay. I have used svn to checkout openlayers into program files from
> github.
> If I do an svn update on that checked out directory, I get:
> Tree conflict: C:\Program Files\openlayers\.gitignore
> Tree conflict: C:\Program Files\openlayers\apidoc_config
> Tree conflict: C:\Program Files\openlayers\art
> Tree conflict: C:\Program Files\openlayers\build
> Tree conflict: C:\Program Files\openlayers\doc
> Tree conflict: C:\Program Files\openlayers\doc_config
> Tree conflict: C:\Program Files\openlayers\examples
> Tree conflict: C:\Program Files\openlayers\img
> Tree conflict: C:\Program Files\openlayers\lib
> Tree conflict: C:\Program Files\openlayers\license.txt
> Added: C:\Program Files\openlayers\notes
> Added: C:\Program Files\openlayers\notes\2.12.md
> Added: C:\Program Files\openlayers\readme.md
> Tree conflict: C:\Program Files\openlayers\release-license.txt
> Tree conflict: C:\Program Files\openlayers\repository-license.txt
> Tree conflict: C:\Program Files\openlayers\tests
> Tree conflict: C:\Program Files\openlayers\theme
> Tree conflict: C:\Program Files\openlayers\tools
> Completed: At revision: 10623
> Warning!: One or more files are in a conflicted state.
> What the???
> Anyway, at this point, I gave up. I blew it away and checked out a fresh
> instance. I applied my patches and now it compiles okay. I'll close the
> trac.
> Notice: This email and any attachments are confidential. If received in
> error please destroy and immediately notify us. Do not copy or disclose
> the contents.
> Dev mailing list
> Dev at .osgeo
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
View this message in context: http://osgeo-org.1560.n6.nabble.com/Re-OpenLayers-3618-Problems-with-closure-compiler-under-windows-tp4466544p4470427.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
