[OpenLayers-Dev] How to finish a path
Vidal, Antoni antoni.vidal at icc.cat
Tue Jan 10 05:13:36 EST 2012
At first I discard maxVertices because I use freeHand mode and documentation tells that maxVertices didn't work using it. Anyway, I tryed, and it seems to work properly.
Anyway, I'm interested in launch a double click using source.
Any idea?
Thanks in advance.
Antoni Vidal
Unitat d'Aplicacions SIG-WEB
Institut Cartogràfic de Catalunya <http://mercuri.icc.cat/website/mob_nf/mob1/mob2/inici2.htm?CONSULTA=Institut%20Cartogr%25E0fic%20de%20Catalunya&XYADDRESS=429486:4580392>
Parc de Montjuïc, E-08038 Barcelona
Tel. (+34) 93 567 15 00 (ext. 3228)
www.icc.cat <http://www.icc.cat/>
De: Eric Lemoine [mailto:eric.lemoine at camptocamp.com]
Enviat: lunes, 09 de enero de 2012 18:39
Per a: Vidal, Antoni
A/c: openlayers-dev at lists.osgeo.org
Tema: Re: [OpenLayers-Dev] How to finish a path
On Monday, January 9, 2012, Vidal, Antoni <antoni.vidal at icc.cat> wrote:
> Hi list,
> I need to force finish a path drawned in freehand mode when it arrives to 500 points. I have a points counter and when it have 500,  launch a function that makes a process (draws a chart), but mouse pointer continue allowing users to draw new points. I woold like to force a double click at this moment to finish the path. My question is, how can I force, simulate, launch a double click?
Have you tried the Handler.Path maxVertices option? <http://dev.openlayers.org/releases/OpenLayers-2.11/doc/apidocs/files/OpenLayers/Handler/Path-js.html#OpenLayers.Handler.Path.maxVertices>
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120110/1a8e041e/attachment.html
More information about the Dev mailing list
