[OpenLayers-Dev] OpenLayers and accessibility
Roald de Wit list at rdewit.net
Tue Jan 31 20:20:20 EST 2012
Hi Thijs,
The license incompatibility (GPL v3) may become an issue if code gets
used from your project. Is there any way you could contribute the
relevant code to OpenLayers (which is under the 2-Clause BSD license),
provided that C2C wants to incorporate your code of course?
Thanks, Roald
On 01/02/12 03:31, Thijs Brentjens wrote:
> Hi Eric.
> In the Netherlands we have Web accessibility guidelines. For a project
> (called GEOZET) in which these guidelines are very important, we have
> made some changes and additions using ExtJS. So I'm not sure if that
> is okay with you as well. I haven't been coding myself, but code can
> be found at:
> https://github.com/geozet/geozet. The dir ./src/ contains javascript
> code.
> Added functionality for accessibility includes:
> - another PanZoomBar, that is accessible using the keyboard. For code
> see:
> https://github.com/geozet/geozet/blob/master/src/Geozet/lib/Geozet/widgets/PanZoomBar.js
> - a new renderer, for vector points, in HTML. This way the popups are
> also accessible with the keyboard.
> - sorting of features in the map, so users can use Tab to go through
> the features on the map from left to right, top to bottom.
> The "alt" attribute is not used on the map images though. Don't
> remember why we didn't do that.
> The final result is not online yet, but the code is open source. If
> you'd like to see a working demo (with slightly data in it) in action,
> I'm hosting one here: http://nieuwsinkaart.nl/geozetnijmegen/
> HTH
> Thijs
> On 01/31/2012 04:47 PM, Eric Lemoine wrote:
>> Hi devs
>> Some of us at Camptocamp are currently extending an OpenLayers
>> application to make it accessible [*]. For this work we need to modify
>> OpenLayers in a number of areas. Here are the features/modifications
>> we are considering:
>> - navigate the map with the keyboard when the map div gets the focus
>> (currently the KeyboardDefaults control works with the document only)
>> - make the panel buttons accessible, by using appropriate markups
>> (<a>+<img>  in place of<div>)
>> - add "alt" attributes to<img>  elements
>> We'd like to avoid duplicated effort, so we're interested to know if
>> others are working, or have worked, on making OpenLayers more
>> accessible.
>> Thanks,
>> [*]<http://en.wikipedia.org/wiki/Web_accessibility>
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
