[OpenLayers-Dev] Util methods for vendor prefixes
Gregers Gram Rygg gregersrygg at gmail.com
Thu Jun 28 04:27:13 PDT 2012
Hey,
Just want to inform about a new Util module that might be useful to some of you.
A lot of new browser features have vendor-prefixes. Sounds simple to
use, but from my experience they are a total mess. There are 3
variants: js, dom-style and css. Internet Explorer is different than
the others (shock), and to make the confusion complete, webkit allows
several variants of the dom-style properties.
To fix this I made a new module that can detect the presence of
features and return the prefixed property for the browser in use.
These features are prefixed for a reason, and the spec might change.
So be careful which features you use ;)
Some examples:
// js prefix
var requestAnimationFrame = OpenLayers.Util.vendorPrefix.js(window,
"requestAnimationFrame");
// => "webkitRequestAnimationFrame"
window[requestAnimationFrame](...);
// style prefix
var transform = OpenLayers.Util.vendorPrefix.style("transform");
// => "WebkitTransform"
if (transform) {
    div.style[transform] = "scale(2)";
} else {
    // fallback ?
    div.style.width = "200%";
    div.style.height = "200%";
// css prefix
var cssTransform = OpenLayers.Util.vendorPrefix.css("transform");
// => "-webkit-transform"
var transition = OpenLayers.Util.vendorPrefix.style("transition");
// => "WebkitTransition"
div.style[transition] = cssTransform + " 2s ease-in";
A bit more info here: https://github.com/openlayers/openlayers/pull/546
Cheers,
Gregers
More information about the Dev mailing list
