[OpenLayers-Dev] Firefox and canvas, strange behavior
Andreas Hocevar
ahocevar at opengeo.org
Tue Mar 6 17:33:50 EST 2012
See https://github.com/openlayers/openlayers/pull/297.
Andreas.
On Tue, Mar 6, 2012 at 8:05 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> Hi,
> I found a solution: in Firefox, it is not enough to set
> img.crossOrigin = null;
> What you need to do is
> img.removeAttribute("crossorigin");
> Also note a typo in Tile/Image.js:
> if (url.substr(0, 5 !== 'data:')) {
> should read
> if (url.substr(0, 5) !== 'data:') {
> Andreas.
> On Fri, Feb 17, 2012 at 10:26 AM, Frederic Junod
> <frederic.junod at camptocamp.com> wrote:
>> Hello all,
>> I'm trying to create a demo to shows the new canvas capabilities in
>> OpenLayers [1].
>> The attached example loads a basic OSM layer and turns the tiles into
>> grayscale. This works great with Chrome 16 and 18; even IE9 displays
>> the layer correctly [2].
>> But I can't make it work with FireFox 10: the tiles are still in color
>> (and in the wrong position). Using firebug, I see that the img src are
>> correct (data url in base64).
>> Repaint bug? src size limitation?
>> Any advice welcome
>> fredj
>> [1] https://github.com/openlayers/openlayers/commit/ad201f3a80827f8189d9d798fb8c93fe67fd8865
>> [2] With IE9, a local proxy must be created, this comments inside the
>> attached file.
>> Frédéric Junod
>> Camptocamp SA
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
Andreas Hocevar
More information about the Dev
