[OpenLayers-Dev] Re: 2.11 sketchstarted - new event?
Richard Greenwood
richard.greenwood at gmail.com
Sun Mar 11 21:41:26 EDT 2012
Xavier -
Thank you very much for your work on this! I have not tested your
patches yet, but I wanted to say thank you right away. It looks very
much like I had in mind. I am not seeking any new functionality, I am
just hoping to see < 2.11 functionality restored. I also like what you
are doing with the "drawing" property, if I understand it correctly.
I have my app working under 2.11 by using a layer event handler for
sketchcomplete and callbacks for sketchstarted (sketchcreated). But
this seems a very ugly solution.
Again - thank you!
Rich
On Sun, Mar 11, 2012 at 4:09 PM, Xavier Mamano (jorix)
<xavier.mamano at gmail.com> wrote:
> Hi,
> See https://github.com/openlayers/openlayers/pull/314 +
> https://github.com/openlayers/openlayers/pull/315
> Details:
> * The "DrawFeature" control does not trigger "sketchstarted" event when
> using a "Handler.Point".
> * It may be interesting to distinguish between "sketchmodified" before
> "sketchstarted" and after (not Implemented)
> Tests run on: IE8 IE9 Chrome17 FF10 and Safari5
> Xavier Mamano
> erilem wrote
>> On Thu, Mar 8, 2012 at 6:00 PM, Richard Greenwood
>> <richard.greenwood@> wrote:
>>> Earlier this week there was discussion about the 2.11 change in
>>> behavior of the of the sketchstarted event.
>>> http://osgeo-org.1560.n6.nabble.com/2-11-SketchStarted-td4550864.html
>>> Some of us were relying on that event to detect when the first vertex
>>> was added to a path or polygon. Eric Lemoine suggested a workaround
>>> that is okay with callbacks, but not so good with LAYER.events.on().
>>> How about a new event 'firstvertexadded' that does what sketchstarted
>>> did before 2.11?
>> If someone can do a pull request introducing a sketchcreated event
>> type as I described it in the previous thread, I can review it and
>> merge it into master (or 2.12 branch). The patch would basically
>> involve (a) replacing the current sketchstarted event by
>> sketchcreated, and (b) triggering sketchstarted when the first vertex
>> is added (and (c) adding tests, and making sure they pass in multiple
>> browsers!).
>> Thanks.
>> Eric Lemoine
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel : 00 33 4 79 44 44 96
>> Mail : eric.lemoine@
>> http://www.camptocamp.com
>> Dev mailing list
>> Dev at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> View this message in context: http://osgeo-org.1560.n6.nabble.com/2-11-sketchstarted-new-event-tp4559041p4568364.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
Richard Greenwood
www.greenwoodmap.com
More information about the Dev
