[OpenLayers-Dev] Exception in
OpenLayers.Layer.Grid.removeBackBuffer
Tim-Hinnerk Heuer
th.heuer at gmail.com
Wed Mar 14 17:58:54 EDT 2012
Hi Andreas,
Just looking in the source, I see what you mean:
* Method: clone
* Create a clone of this layer
* Returns:
* {<OpenLayers.Layer.WMS>} An exact clone of this layer
clone: function (obj) {
if (obj == null) {
obj = new OpenLayers.Layer.WMS(this.name,
this.url,
this.params,
this.getOptions());
//get all additions from superclasses
obj = OpenLayers.Layer.Grid.prototype.clone.apply(this, [obj]); //
POINTS TO Grid
// copy/set any non-init, non-simple values here
return obj;
but
* APIMethod: clone
* Parameters:
* obj - {Object} Is this ever used?
* Returns:
* {<OpenLayers.Layer.Grid>} An exact clone of this
if (obj == null) {
obj = new OpenLayers.Layer.Grid(this.name,
this.url,
this.params,
this.getOptions());
obj = OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this,
[obj]);
if (this.tileSize != null) {
obj.tileSize = this.tileSize.clone();
// we do not want to copy reference to grid, so we make a new array
obj.grid = []; // THIS IS WHAT YOU MEAN, RIGHT?
obj.gridResolution = null;
return obj;
I don't know how to figure out the problem quickly. I might just have to
leave the fix as is for now, but this might be good to keep in the back of
our minds in case we stumble upon this problem again.
Cheers,
Tim
++Tim Hinnerk Heuer++
Twitter: @timhheuer
Blog: http://www.thheuer.com
On Wed, Mar 14, 2012 at 9:14 PM, Andreas Hocevar <ahocevar at opengeo.org>wrote:
> The clone method does not clone the grid, so it is not affected by the
> state of any images in the grid, and it also does not clone any
> backbuffer related properties. So the issue must be a different one.
> Andreas.
> On Wed, Mar 14, 2012 at 8:36 AM, Tim-Hinnerk Heuer <th.heuer at gmail.com>
> wrote:
> > Just guessing here:
> > Maybe the state of a layer changes when the tiles finish loading to
> > something more consistent that can be cloned and maybe the <img> element
> is
> > in a different state or not even there while it is loading? I seem to
> > remember something like that when I was doing the VideoWMS. Correct me if
> > I'm wrong.
> > Thanks,
> > Tim
> > On Wed, Mar 14, 2012 at 8:28 PM, Eric Lemoine <
> eric.lemoine at camptocamp.com>
> > wrote:
> >> On Wed, Mar 14, 2012 at 8:08 AM, Andreas Hocevar <ahocevar at opengeo.org>
> >> wrote:
> >> > The only occasions I could think of that could potentially make
> >> > this.backBuffer both non-null and not a child of this.div is when a
> >> > layer is cloned during tile loading
> >> I had thought about this too. But I'm still failing to understand how
> >> cloning can lead to this state. Do you mind elaborating a bit? Thank
> >> you.
> >> Eric Lemoine
> >> Camptocamp France SAS
> >> Savoie Technolac, BP 352
> >> 73377 Le Bourget du Lac, Cedex
> >> Tel : 00 33 4 79 44 44 96
> >> Mail : eric.lemoine at camptocamp.com
> >> http://www.camptocamp.com
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120315/8e5d3abb/attachment.html
More information about the Dev
