[OpenLayers-Dev] removeExcessTiles doesn't work properly
kikuchan at uranus.dti.ne.jp kikuchan at uranus.dti.ne.jp
Wed May 23 17:56:25 EDT 2012
Hi list.
I've found a potential bug in OpenLayers.Layer.Grid class
when I'm trying to make a subclass of the class.
A function removeExcessTiles() doesn't work properly in following situation:
1. initGriddedTiles() founds minRows and minCols are 1, 3
2. then grid will be [[a, b, c]] for example.
3. next time of calling initGriddedTiles founds minRows and minCols are 2, 2
4. then grid will be [[a, b, c], [d, e]] after the do-while.
5. removeExcessTiles(2, 2) eliminate 'c', AND 'e' objects.
  (because it uses 'pop' for each rows)
6. tileData[i].tile.draw() refers destroy()ed data, and it crashes.
I've attached a tiny patch to fix it.
Best regards,
Kikuchan
Type: application/octet-stream
Desc: Grid.patch
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120524/16b53a35/Grid.obj
More information about the Dev mailing list
