[OpenLayers-Dev] Possible bug: Fixed vector layers and z-indexing
gorybunny cedricseah at stee.stengg.com
Fri Sep 7 02:34:00 PDT 2012
Thank you very much for that clear explanation as to the purpose of the
isFixed property. Perhaps that snippet of information should be included in
the api docs to discourage cowboy developers like myself from misusing it :)
I was indeed trying to implement map decorators like the legend / north
arrow above my maps.
Eventually, I went with the simpler(?) route using CSS to position these
elements relative to the map div, styled with a z-index of 2000.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Possible-bug-Fixed-vector-layers-and-z-indexing-tp3890867p5000373.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
