[OpenLayers-Dev] Drawing user-selected kml files
Xavier Mamano (jorix) xavier.mamano at gmail.com
Tue Apr 2 10:14:36 PDT 2013
Try:
var format = new OpenLayers.Format.KML({
				extractStyles: true,
				extractAttributes: true,
				maxDepth: 2
var features = format.read("your kml text");
See: http://openlayers.org/dev/examples/vector-formats.html
Regards,
Ailin wrote
> Hello,
> I'm looking for a way to import a kml file via html5 input type file and
> render it on my map.
> I've found a lot of examples but all of them are using a predetermined
> url, for example :
> The problem is i want my program to be able to render files that users
> select themselves but all the examples i found require an URL which i
> can't have with HTML5 input type file (security restriction).
> Thank you for your time and help
View this message in context: http://osgeo-org.1560.n6.nabble.com/Drawing-user-selected-kml-files-tp5044077p5044113.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
