[OpenLayers-Dev] OL3, adding mapguide source
David Hequet
david.hequet at free.fr
Fri Apr 19 02:17:12 PDT 2013
Thank you, i will post new question in the ol3-dev list (i didn't found it,
so i came here :) )
- Mapguide really work with scale, when you ask for a single image, you
request it with the needed scale.
When working with tile, you use the scale index (wich can be the resolution
index too, but you have to convert the map scale list into resolution list).
- Yes, it is what I concluded from it too.
- Yep, that's why i will begin with single image, it is easier :)
View this message in context: http://osgeo-org.1560.x6.nabble.com/OL3-adding-mapguide-source-tp5047985p5048239.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
