[OpenLayers-Dev] Added OSM relation support
Roland Olbricht roland.olbricht at gmx.de
Mon Feb 25 11:35:12 PST 2013
> I've been using OpenLayers for quite long and recently I was using its HTTP
> protocol to download some OSM data from OpenStreetMap's Overpass API. I
> needed to work with some polygon with inner holes and realized that (at
> least in my version "Release 2.12") there was no support for OSM relations.
Thank you. This is very useful even if some special cases do not work yet
perfectly.
> http://energia.deusto.es/BizkaiSenseIn/
It works when I check the box "INDICATOR 23". Are there more examples inside?
Where can I find the source code?
Best regards,
Roland
More information about the Dev mailing list
