[OpenLayers-Dev] case restrictions for use of EPSG codes
Eric Blasenheim eric.blasenheim at pb.com
Mon Mar 25 08:11:13 PDT 2013
I have seen a number of examples where unknowledgeable coders have created their map projection or assigned layer projections using something like "epsg:3857" and thought this was working.
>From what I have seen, this is not supported by Open Layers and seems to do nothing.   A transform, for example, between EPSG:4326 and epsg:3857 returns the identical input coordinates.
Is there a reason for this being case sensitive?
Eric Blasenheim
More information about the Dev mailing list
