[OpenLayers-Dev] How to return a string from OpenLayers.Format.WKT write
kamarajugadda manjula kamarajugaddamanjula at gmail.com
Wed May 21 22:43:04 PDT 2014
//OpenLayers.ProxyHost = "proxy.cgi?url=";
OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url=";
var wps = "http://localhost:8080/geoserver/wps",
    capabilities, // the capabilities, read by Format.WPSCapabilities::read
    process; // the process description from Format.WPSDescribeProcess::read
// get some capabilities
getCapabilities();
// create the UI
var layer = new OpenLayers.Layer.Vector("Scratchpad");
var toolbar = new OpenLayers.Control.EditingToolbar(layer);
toolbar.addControls([new OpenLayers.Control.ModifyFeature(layer, {
    title: "Select feature"
var map = new OpenLayers.Map('map', {
    controls: [
        toolbar,
        new OpenLayers.Control.ZoomPanel(),
        new OpenLayers.Control.PanPanel()
    layers: [
        new OpenLayers.Layer.WMS(
            "OSM", "http://maps.opengeo.org/geowebcache/service/wms",
            {layers: "openstreetmap", format: "image/png"}
        ), layer
map.zoomToMaxExtent();
// add behavior to html elements
document.getElementById("processes").onchange = describeProcess;
// using OpenLayers.Format.WPSCapabilities to read the capabilities
function getCapabilities() {
    OpenLayers.Request.GET({
        url: wps,
        params: {
            "SERVICE": "WPS",
            "REQUEST": "GetCapabilities"
        success: function(response){
            capabilities = new OpenLayers.Format.WPSCapabilities().read(
                response.responseText
            var dropdown = document.getElementById("processes");
            var offerings = capabilities.processOfferings, option;
            // populate the dropdown
            for (var p in offerings) {
                option = document.createElement("option");
                option.innerHTML = offerings[p].identifier;
                option.value = p;
                dropdown.appendChild(option);
// using OpenLayers.Format.WPSDescribeProcess to get information about a
// process
function describeProcess() {
    var selection = this.options[this.selectedIndex].value;
        url: wps,
        params: {
            "SERVICE": "WPS",
            "REQUEST": "DescribeProcess",
            "VERSION": capabilities.version,
            "IDENTIFIER": selection
        success: function(response) {
            process = new OpenLayers.Format.WPSDescribeProcess().read(
            ).processDescriptions[selection];
            buildForm();
// dynamically create a form from the process description
function buildForm() {
    document.getElementById("abstract").innerHTML = process["abstract"];
    document.getElementById("input").innerHTML = "<h3>Input:</h3>";
    document.getElementById("output").innerHTML = "";
    var inputs = process.dataInputs, supported = true,
        sld = "text/xml; subtype=sld/1.0.0",
        input;
        //var change=inputs.innerHTML.toFixed(2);
    for (var i=0,ii=inputs.length; i<ii; ++i) {
    alert("Hello! I am an alert box!!");
        input = inputs[i];
        if (input.complexData) {
        //alert("Hello! I am an alert box in complexdata !!");
            var formats = input.complexData.supported.formats;
            if (formats["application/wkt"]) {
            //alert("Hello! I am an alert box in app/wkt!!");
                addWKTInput(input);
            } else if (formats["text/xml; subtype=wfs-collection/1.0"]) {
            //alert("Hello! I am an alert box in text/xml!!");
                addWFSCollectionInput(input);
            } else if (formats["image/tiff"]) {
               // addRasterInput(input);
                //alert(truncator(5.1231231, 1));
                //alert("Hello! I am an alert box in image/tiff!!");
                addRasterInput(truncator(input,2));
            } else if (formats[sld]) {
            //alert("Hello! I am an alert box in formatssld!!");
                addXMLInput(input, sld);
            } else {
                supported = false;
        } else if (input.boundingBoxData) {
        alert("Hello! I am an alert box in bounding box!!");
             // var change=input.innerHTML.toFixed(2);
            addBoundingBoxInput(input);
        } else if (input.literalData) {
        //alert("Hello! I am an alert box in literal box!!");
            addLiteralInput(input);
        } else {
            supported = false;
        if (input.minOccurs > 0) {
        //alert("Hello! I am an alert box in minoccurs box!!");
document.getElementById("input").appendChild(document.createTextNode("* "));
    if (supported) {
        var executeButton = document.createElement("button");
        executeButton.innerHTML = "Execute";
        document.getElementById("input").appendChild(executeButton);
        executeButton.onclick = execute;
    } else {
        document.getElementById("input").innerHTML = '<span
class="notsupported">' +
            "Sorry, the WPS builder does not support the selected process."
            "</span>";
// helper function to dynamically create a textarea for geometry (WKT) data
// input
function addWKTInput(input, previousSibling) {
alert("Hello! I am an alert box in dynamically create a textarea for
geometry data input!!");
    var name = input.identifier;
    var container = document.getElementById("input");
    var label = document.createElement("label");
    label["for"] = name;
    label.title = input["abstract"];
    label.innerHTML = name + " (select feature, then click field):";
    previousSibling && previousSibling.nextSibling ?
        container.insertBefore(label, previousSibling.nextSibling) :
        container.appendChild(label);
    var field = document.createElement("textarea");
    field.onclick = function () {
    alert("Hello! I am an alert box in onclick!!");
        if (layer.selectedFeatures.length) {
        alert("Hello! I am an alert box in selected features function for
geometry data input writing!!");
            this.innerHTML = new OpenLayers.Format.WKT().write(
                //layer.selectedFeatures[0]
                //name.length();
                //alert(trun.toFixed(2));
        createCopy(input, this, addWKTInput);
    field.onblur = function() {
        input.data = field.value ? {
            complexData: {
                mimeType: "application/wkt",
                value: this.value
        } : undefined;
    field.title = input["abstract"];
    field.id = name;
        container.insertBefore(field,
previousSibling.nextSibling.nextSibling) :
        container.appendChild(field);
// helper function for xml input
function addXMLInput(input, type) {
    var field = document.createElement("input");
    field.value = name + " (" + type + ")";
            complexData: {
                mimeType: type,
                value: this.value
        } : undefined;
    document.getElementById("input").appendChild(field);
// helper function to dynamically create a WFS collection reference input
function addWFSCollectionInput(input) {
    field.value = name + " (layer on demo server)";
    addValueHandlers(field, function() {
        input.reference = field.value ? {
            mimeType: "text/xml; subtype=wfs-collection/1.0",
            href: "http://geoserver/wfs",
            method: "POST",
            body: {
                wfs: {
                    version: "1.0.0",
                    outputFormat: "GML2",
                    featureType: field.value
        } : undefined;
// helper function to dynamically create a raster (GeoTIFF) url input
function addRasterInput(input) {
    var url = window.location.href.split("?")[0];
    field.value = url.substr(0, url.lastIndexOf("/")+1) +
"data/tazdem.tiff";
    (field.onblur = function() {
        input.reference = {
            mimeType: "image/tiff",
            href: field.value,
            method: "GET"
// helper function to dynamically create a bounding box input
function addBoundingBoxInput(input) {
    field.value = "left,bottom,right,top (EPSG:4326)";
        input.boundingBoxData = {
            projection: "EPSG:4326",
            bounds: OpenLayers.Bounds.fromString(field.value)
// helper function to create a literal input textfield or dropdown
function addLiteralInput(input, previousSibling) {
    var anyValue = input.literalData.anyValue;
    // anyValue means textfield, otherwise we create a dropdown
    var field = document.createElement(anyValue ? "input" : "select");
    field.id = name;
        container.insertBefore(field, previousSibling.nextSibling) :
    if (anyValue) {
        var dataType = input.literalData.dataType;
        field.value = name + (dataType ? " (" + dataType + ")" : "");
                literalData: {
                    value: field.value
            } : undefined;
            createCopy(input, field, addLiteralInput);
    } else {
        var option;
        option.innerHTML = name;
        field.appendChild(option);
        for (var v in input.literalData.allowedValues) {
            option.value = v;
            option.innerHTML = v;
        field.onchange = function() {
            input.data = this.selectedIndex ? {
                literalData: {
                    value: this.options[this.selectedIndex].value
            } : undefined;
// if maxOccurs is > 1, this will add a copy of the field
function createCopy(input, field, fn) {
    if (input.maxOccurs && input.maxOccurs > 1 && !field.userSelected) {
        // add another copy of the field - we don't check maxOccurs
        field.userSelected = true;
        var newInput = OpenLayers.Util.extend({}, input);
        // we recognize copies by the occurrence property
        newInput.occurrence = (input.occurrence || 0) + 1;
        process.dataInputs.push(newInput);
        fn(newInput, field);
// helper function for adding events to form fields
function addValueHandlers(field, onblur) {
    field.onclick = function() {
        if (!this.initialValue) {
            this.initialValue = this.value;
            this.value = "";
        if (!this.value) {
            this.value = this.initialValue;
            delete this.initialValue;
        onblur.apply(this, arguments);
// execute the process
function execute() {
    var output = process.processOutputs[0];
    var input;
    // remove occurrences that the user has not filled out
    for (var i=process.dataInputs.length-1; i>=0; --i) {
        input = process.dataInputs[i];
        if ((input.minOccurs === 0 || input.occurrence) && !input.data &&
!input.reference) {
            OpenLayers.Util.removeItem(process.dataInputs, input);
    process.responseForm = {
        rawDataOutput: {
            identifier: output.identifier
    if (output.complexOutput &&
output.complexOutput.supported.formats["application/wkt"]) {
        process.responseForm.rawDataOutput.mimeType = "application/wkt";
    OpenLayers.Request.POST({
        url: wps,
        data: new OpenLayers.Format.WPSExecute().write(process),
        success: showOutput
// add the process's output to the page
function showOutput(response) {
    var result = document.getElementById("output");
    result.innerHTML = "<h3>Output:</h3>";
    var features;
    var contentType = response.getResponseHeader("Content-Type");
    if (contentType == "application/wkt") {
        features = new OpenLayers.Format.WKT().read(response.responseText);
    } else if (contentType == "text/xml; subtype=wfs-collection/1.0") {
        features = new
OpenLayers.Format.WFST.v1_0_0().read(response.responseText);
    if (features && (features instanceof OpenLayers.Feature.Vector ||
features.length)) {
        layer.addFeatures(features);
        result.innerHTML += "The result should also be visible on the map.";
    result.innerHTML += "<textarea>" + response.responseText +
"</textarea>";
                 -----K.Manjula-------
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20140522/90d595e0/attachment-0001.html>
More information about the Dev mailing list
