[OpenLayers-Dev] Openlayers 2.13.1 Google maps not showing recently (Sep 2015)
Jason Lee jaslee.st at gmail.com
Thu Nov 19 02:33:46 PST 2015
This has happened again since this week. Digging around I have seen
discussion here about a better solution:-
https://github.com/openlayers/openlayers/issues/1450
Someone even helpfully supplied a minified Openlayers.js fix:-
https://github.com/vitalidze/traccar-web/blob/dev/src/main/webapp/js/openlayers/OpenLayers.js
https://raw.githubusercontent.com/vitalidze/traccar-web/dev/src/main/webapp/js/openlayers/OpenLayers.js
Works for me.
On 2 September 2015 at 18:46, laurentK2 <lboileau at k2geospatial.com> wrote:
> We are experiencing the same issue.
> A colleague noticed that the problem arises only if a Google Maps layer is
> set as the base layer when initializing the map. We're able to see a Google
> base layer when another type of layer was used as the base layer (in our
> case WMS) to initialize the map.
> In the meantime, we'll be requesting version 3.2 as per Jaslee's
> suggestion.
> Thank you.
> http://osgeo-org.1560.x6.nabble.com/Openlayers-2-13-1-Google-maps-not-showing-recently-Sep-2015-tp5222280p5222341.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20151119/9946ebee/attachment.html>
More information about the Dev mailing list
