[OpenLayers-Dev] Openlayers 2.13.1 Google maps not showing recently (Sep 2015)
laurentK2 lboileau at k2geospatial.com
Wed Sep 2 10:46:12 PDT 2015
We are experiencing the same issue.
A colleague noticed that the problem arises only if a Google Maps layer is
set as the base layer when initializing the map. We're able to see a Google
base layer when another type of layer was used as the base layer (in our
case WMS) to initialize the map.
In the meantime, we'll be requesting version 3.2 as per Jaslee's suggestion.
Thank you.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Openlayers-2-13-1-Google-maps-not-showing-recently-Sep-2015-tp5222280p5222341.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
