[OpenLayers-Trac] Re: [OpenLayers] #2913: Request abort test is failing
OpenLayers trac-20090302 at openlayers.org
Tue Dec 14 18:31:32 EST 2010
  Reporter:  tschaub           |       Owner:  tschaub
      Type:  bug               |      Status:  reopened
  Priority:  minor             |   Milestone:  2.11 Release
 Component:  Request           |     Version:  2.10
Resolution:                    |    Keywords:
     State:  Needs Discussion  |
Comment(by jorix):
 Replying to [comment:17 erilem]:
 > But do we care about the response?
 No, the answer does not matter. The question is that "RequestC" do not get
 an 4-DONE like "RequestB". But this test is hard to fail, we can only
 t.plan(8), and also remove the delay.
 > I just think we shouldn't use {{{Protocol.HTTP}}} in tests for
 {{{Request}}}.
 Yes yes, I agree with you. In the file attachment:Request-W3C(2).patch now
 the test only uses Request.js
 I verified that the new test still fails without r10959 (in IE8 & FF), and
 it works when applied (in FF,IE,CH & Safari)
Ticket URL: <http://trac.openlayers.org/ticket/2913#comment:18>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
