[OpenLayers-Trac] [OpenLayers] #2988: Format.OSM.write doesn't
reproject
trac-20090302 at openlayers.org
Wed Dec 22 01:50:30 EST 2010
#2988: Format.OSM.write doesn't reproject
Reporter: erilem | Owner: tschaub
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Format | Version: SVN
Keywords: | State:
The summary says it all.
Here's what Arnd Wipperman wrote on the mailing list about this:
On Tuesday, December 21, 2010, Arnd Wippermann <arnd.wippermann at web.de>
wrote:
> Hi,
> for writing OSM data there is no call to geometry.transform
> you can patch the file OSM.js
> createXML: {
> 'point': function(point) {
> var id = null;
> var geometry = point.geometry ? point.geometry : point;
> //at line 349 add this 5 lines
> if (this.externalProjection && this.internalProjection) {
> geometry = geometry.clone();
> geometry.transform(this.internalProjection,
> this.externalProjection);
> var already_exists = false; // We don't return anything if
the
> node
> and the transformation for writing works.
> What i don't understand, that an externalProjection given in the options
is
> used instead of
> // OSM coordinates are always in longlat WGS84
> this.externalProjection = new OpenLayers.Projection("EPSG:4326");
> as set in the initialize function, what should overwrite the options
value.
> With the patch one can create OSM data in different projection than
> EPSG:4326.
> Arnd
Ticket URL: <http://trac.openlayers.org/ticket/2988>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
