[OpenLayers-Trac] Re: [OpenLayers] #2913: Request abort test is failing
OpenLayers trac-20090302 at openlayers.org
Thu Nov 18 12:08:14 EST 2010
 Reporter:  tschaub  |       Owner:  tschaub
     Type:  bug      |      Status:  new
 Priority:  minor    |   Milestone:  2.11 Release
Component:  Request  |     Version:  2.10
 Keywords:           |       State:  Needs More Work
Comment(by erilem):
 Replying to [comment:4 jorix]:
 > Replying to [comment:3 erilem]:
 > > ... But I'm not sure this is a problem, we may actually not need abort
 to set readyState to 0.
 > Yes, it is not necessary but: the variable "request._aborted" (used in
 Request.js) is not W3C standard, W3C says that "request.readyState" should
 be 0 after an abort, should be better to write the code using this (now it
 is not possible, due to the failure of "XMLHttpRequest.js")
 Right. But with the browsers not triggering {{{onreadystatechange}}} on
 abort we're out of luck, aren't we?
Ticket URL: <http://trac.openlayers.org/ticket/2913#comment:5>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
