[OpenLayers-Trac] [OpenLayers] #2847: viewRequestID regression and mixin issue
OpenLayers trac-20090302 at openlayers.org
Fri Sep 17 18:44:14 EDT 2010
 Reporter:  ahocevar    |       Owner:  ahocevar
     Type:  bug         |      Status:  new
 Priority:  major       |   Milestone:  2.11 Release
Component:  Tile.Image  |     Version:  2.10
 Keywords:              |       State:  Review
 r10755 brings a regression, because the code shuffling needed for making
 Tile.Image.IFrame a mixin caused an unintended change in execution flow:
 renderTile needs to update the viewRequestID every time, and not just when
 a new imgDiv is created.
 The way Tile.Image.IFrame is mixed in will cause the mixin to always be
 applied, unless the maxGetUrlLength is explicitly set.
 The attached patch fixes these regressions. All tests pass. Thanks for any
 review
Ticket URL: <http://trac.openlayers.org/ticket/2847>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
