[OpenLayers-Trac] Re: [OpenLayers] #3419: Tile simplifications and partial rewrite
OpenLayers trac-20090302 at openlayers.org
Wed Aug 10 07:27:35 EDT 2011
 Reporter:  ahocevar  |       Owner:  ahocevar
     Type:  feature   |      Status:  new
 Priority:  minor     |   Milestone:  2.12 Release
Component:  Tile      |     Version:  2.10
 Keywords:            |       State:  Review
Comment(by erilem):
 Replying to [comment:21 ahocevar]:
 > Thanks a lot for the review Eric.  I agree with your suggestions, so if
 you could create a new patch that would be great. Just one note: I had
 changed imgDiv to image already in one of the #3061 patches, but decided
 to not do it in #3419. Even if it's not an API property, people may be
 relying on it, and we use it in hundreds of test assertions as well. But I
 won't object if you want to make this change.
 No, I agree with you.
 > Also I seem to remember that I had something like (singleTile & 1) |
 ((indexOf() !- -1) & 2) in a previous iterations and it did not work as
 expected. But if you can add test cases that would be great.
 I'll give it a try.
 > Regarding the image loading icons: I saw them in FF5 as well and did not
 find a way to get rid of them so far. I'd say I'll wait for your updated
 patch, and then give this another look.
 Thanks.
 > Also, now that r12185 was reverted, we need to set the initial opacity
 when creating a tile. I can add this after your new patch as well.
 Sounds good.
Ticket URL: <http://trac.openlayers.org/ticket/3419#comment:22>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
