[OpenLayers-Trac] Re: [OpenLayers] #3061: Investigate, and if possible implement more efficient tile positioning
OpenLayers trac-20090302 at openlayers.org
Thu Aug 11 11:01:04 EDT 2011
  Reporter:  ahocevar    |       Owner:
      Type:  task        |      Status:  reopened
  Priority:  minor       |   Milestone:  2.12 Release
 Component:  Layer.Grid  |     Version:  2.10
Resolution:              |    Keywords:  mobile
     State:              |
Comment(by erilem):
 Andreas, I'm a bit confused. Do you plan to have this patch in trunk
 eventually? Also, do you want to make the positioning unit configurable,
 or will the {{{positioningUnits}}} option go away? Thank you.
Ticket URL: <http://trac.openlayers.org/ticket/3061#comment:24>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
