[OpenLayers-Trac] Re: [OpenLayers] #3474: ArcGISCache resolutions get compromised by some JS frameworks.
OpenLayers trac-20090302 at openlayers.org
Wed Aug 24 08:16:21 EDT 2011
  Reporter:  dzwarg             |       Owner:  dzwarg
      Type:  bug                |      Status:  reopened
  Priority:  major              |   Milestone:  2.11 Release
 Component:  Layer.ArcGISCache  |     Version:  SVN
Resolution:                     |    Keywords:
     State:  Pullup             |
Comment(by dzwarg):
 Replying to [comment:2 bartvde]:
 > Hi David, thanks for your patch. I've made a minor change to the code
 and the test case, basically the way to prevent this is to use
 hasOwnProperty, see also answer 3 in:
 http://stackoverflow.com/questions/1626530/wrapping-for-in-loops-with-if-
 statements-in-javascript-looping-over-arrays
 > Further than that, this looks good to go. Thanks again.
 Thank you, Bart!
Ticket URL: <http://trac.openlayers.org/ticket/3474#comment:6>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
