[OpenLayers-Trac] Re: [OpenLayers] #3475: Google base layer not showing when switching base layers
OpenLayers trac-20090302 at openlayers.org
Tue Aug 30 03:27:19 EDT 2011
 Reporter:  guendhoer        |       Owner:
     Type:  bug              |      Status:  new
 Priority:  major            |   Milestone:  2.11 Release
Component:  Layer.Google.v3  |     Version:  2.11 RC3
 Keywords:                   |       State:  Needs More Work
Comment(by fredj):
 Replying to [comment:2 bartvde]:
 > Hi, are you able to check if using !OpenLayers.Layer.GoogleNG instead
 would fix your issue?
 You're right: using GoogleNG fixes the issue.
 @guendhoer: you can change your tree layers creation from:
 new OpenLayers.Layer.Google(
   "Google Physical",
   {type: google.maps.MapTypeId.TERRAIN}
 to:
 new OpenLayers.Layer.GoogleNG({
   name: "Google Physical",
Ticket URL: <http://trac.openlayers.org/ticket/3475#comment:8>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
