[OpenLayers-Trac] Re: [OpenLayers] #3591: Alter geometry on the fly
on feature drawing
trac-20090302 at openlayers.org
Thu Dec 8 05:01:38 EST 2011
#3591: Alter geometry on the fly on feature drawing
Reporter: anrikun | Owner:
Type: feature | Status: new
Priority: major | Milestone: 2.12 Release
Component: Feature.Vector | Version: 2.11
Keywords: | State: Awaiting User Feedback
Comment(by anrikun):
Thanks for pointing out these links.
After reviewing them, I don't think that they allow what the patch I have
submitted does.
As a concrete exmaple, here is the code of what I am doing implementing
the new prepareGeometry method. The class below is a vector feature that
represents an arrow between two vertices. I want the head of the arrow to
have a fixed size, that is why I must recalculate the coordinates of the
head each time the feature is redrawn on resolution changes.
I have simplified the code a bit so that only things that matter here are
present.
MyNS.Arrow = OpenLayers.Class(OpenLayers.Feature.Vector, {
points: null, // The 2 end-points of the arrow.
width: 15, // The width of the head of the arrow.
initialize: function(from, to, attributes, style) {
OpenLayers.Feature.Vector.prototype.initialize.apply(this, [new
OpenLayers.Geometry.LineString(), attributes, style]);
this.points = [from.clone(), to.clone()];
getRadiusAngle: function() {
if (this.points[0] && this.points[1]) {
var x = this.points[1].x - this.points[0].x, y = this.points[1].y -
this.points[0].y;
var r = Math.sqrt(x * x + y * y);
var rad = (r > 0) ? ((y > 0) ? 1 : -1) * Math.acos(x / r) : 0;
return {radius: r, angle: 180 * rad / Math.PI};
prepareGeometry: function() {
this.geometry.clearBounds();
this.geometry.components = [];
var ra = this.getRadiusAngle();
if (ra && this.layer && this.layer.map) {
var r = ra.radius;
var a = Math.min(this.layer.map.getResolution() * this.width / 2,
r);
new OpenLayers.Geometry.Point(0, 0),
new OpenLayers.Geometry.Point(r, 0),
new OpenLayers.Geometry.Point(r - a, -a), // Here we use "a" that
is computed based on the current map resolution.
new OpenLayers.Geometry.Point(r - a, a), // This way, the head of
the arrow have a fixed size.
var origin = this.points[0];
this.geometry.move(origin.x, origin.y);
this.geometry.rotate(ra.angle, origin);
CLASS_NAME: 'MyNS.Arrow'
Ticket URL: <http://trac.openlayers.org/ticket/3591#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
